XF 2.0 [How to SQL?]Update every threads' first post in node=x with a string
sbj
Hey,
I want to save a lot of time.
There is node x. In node x there are 1000+ threads.
I want to update all first posts by inserting a one-liner at the end of the first post. How can I do it?
It is tiresome to update all first posts manually with copy/paste over and over again. Any help is appreciated.
Thanks
Wait, with template modifications I can insert messages into posts?
Or are you suggestion I should display that on the templates, but in real it is not saved in the post?
I needed it to be saved in the post.
Any chance doing this without writing a php script and doing it a SQL Update?
Yea, this.
Saving in the database should be something like this:
SQL:
UPDATE xf_post SET message = CONCAT(message, "your additional message")
WHERE post_id IN
    SELECT first_post_id FROM xf_thread
    WHERE node_id = X
Haven't tested it so try it on your dev server first.
  • Like
Reactions: sbj
