How to merge header and body background
Ra
and preserve background modification through the body settings in admin
three more things:
1 how to turn off repeat of the bg picture
2 how to make bg picture resizable in width 1920-to-iphone size
3 how to auto add fog below the bg picture if the forum stretches down farther than the size of the background pic.
:confused:
smth like that
uhu
i used the same color for logo area and background - it looks then the whole thing
but i want to make a picture as my background
and i made a reload rotation of the pics - but then "no repeat" doesn't work and make it tiled on a wide screen
Ra, after putting in your background, comment out this section:
ACP>Styles>Your Style>Style Properties>Header & Navigation>Header>Background. (Click on the color bar and when the color palette pops up, put a check mark in "clear value".
Also go to the Templates>Your Style>header.css and delete this:
	@property "header";
	background-color: @primaryMedium;
	@property "/header";
It's right at the top of the header.css
  • Like
Reactions: Ra
checking out..
yes, thank you! that's what i wanted.
still tiled with clones background.. went to find why
checking out..
You're welcome....
For the clones background, make sure your photo is big enough or it will tile.
  • Like
Reactions: Ra
	@property "header";
Is the second step necessary? IIRC, all I had to do was make the header background transparent, so the underlying body background gradient would start at the top (i.e. behind the header). I never had to remove the code from the template.
(it worked without the deletion)
that's clear, but why then there's a "no-repeat" function for the bground?
btw how to use "position" field? (any faq link)
attached is my current setting
1 - How large is your image?
2 - For "position", try entering top.
No, but it works best that way. You can leave that step out but I prefer the way I mentioned. YMMV. (Your Mileage May Vary)
Why? (I'm not questioning your preference; just curious so I can learn, as I've never been very fluent with CSS, so to speak)
the question is "how to make all images in rotation resizable along with the forum resize" from 1920 to iphone - without left-right shift and tiling
i use different sizes while testing
I don't think you can yet do a background image that scales to 100% height and 100 % width - a workaround is to create one "background" layer div with just an image that is 100% width 100% height and then create another layer "container" div on top that contains everything else.
hey hey I m not so sophisticated
count me as a noob :D
any samples?
(and no fogging ideas? in the sample above it's always new background with a hand-made fog and logo - that's not a good idea..)
stuck with this
updated to beta 2
found, that styles folder had double slash and double rotation.php
cleared all
got to footer.css and cleared background line
fixed
