O Osk Member Sep 27, 2017 #1 hi to all, after setting addthis to work, it does not work, no sharing options are shown. It is not a problem of my style, I test it in the default style and neither are the addthis options to share, I include images so that they see it. Thank you for your help
Jake B. Well-known member Sep 27, 2017 #2 Do you have adblock or anything similar? Pretty sure they'll block these Upvote 0 Downvote
O Osk Member Sep 27, 2017 #3 ohhh sorry, if I have an addblock, it is true if I disable it if the addthis options are displayed. But this is a problem, many people use adblock and all these people will not see it, there is no solution for this? Upvote 0 Downvote
Jake B. Well-known member Sep 27, 2017 #4 Osk said: But this is a problem, many people use adblock and all these people will not see it, there is no solution for this? Click to expand... No solution XF would be able to provide, the extension is explicitly blocking these Last edited: Sep 27, 2017 Upvote 0 Downvote
O Osk Member Sep 27, 2017 #5 Ok, thanks for your help, I think about how I solve it Last edited: Sep 27, 2017 Upvote 0 Downvote
