[cXF] Advertising position after first post
[cXF] Advertising position after first post 1.1.2
Sorry, I need to re-check permissions I guess. You need to have access as a premium member. Sorry for inconvenience.
Thank you Bassman, maybe an other thing,
in "Post: After first post" I tried to add this conditional but it seems it does'nt work (to show in a specific forum).
<xf:if is="in_array({$forum.node_id}, [X,Y,Z])">
Show content..
</xf:if>
Check template cxf_advertising_position_after_first_post and edit it.
It does the same thing, if I put this code below for example, the ad does'nt show up anywhere.
<xf:if is="{$forum.node_id} == 3">
Show content..
</xf:if>
Show content..
</xf:if>
Use this:
<xf:if is="{$__globals.forum.node_id} == 3">
    Show content..
</xf:if>
is there anyway to add padding / margins around ad so that, it wont merge in post area
