FTL
I'm still soldiering on with my forum project and haven't gone live with it yet as I want to do it properly, have a big learning curve and little time.
Apologies if these have been answered before, but frantic Googling, looking on here and the manual didn't reveal the answer to me.
XF is installed on Windows Server 2019 build 1809 (Amazon Web Services image) with all the latest patches. It's running on IIS. I'm using this rather than Apache on Linux to avoid a big command line learning curve, which I simply don't have time for and for easy updating of patches.
1. The one click upgrade on 2.2.4 to 2.2.5 aborts with error, "The following issue was found when determining if a one-click upgrade is possible: The files are not writable". It's not clear to me which files and folders to make writeable. Looking at the folder structure in the installation, they seem to have the right permissions as far as I can see, so I'm stuck. Also, I should add that the test copy installed on my local W10 PC upgraded without a hitch.
2. I've upgraded from PHP 8.0.2 to 8.0.6, but XF is still showing that it's using 8.0.2 in the ACP. How do I switch it to the latest version?
Thanks in advance.
Thanks in advance.
