asma Member Feb 3, 2021 #1 just wondering, is it ok to jump upgrade from 2.1.1 to 2.2.2 ? i mean, should i consider to upgrade by steps, like: 2.1.1 to 2.1.4 2.1.4 to 2.1.7 2.1.7 to 2.2.0 2.2.0 to 2.2.2
Mendalla Well-known member Licensed customer Feb 3, 2021 #2 Nope, just download the upgrade package for the version you want. It will take care of the steps between. I jumped 1.5.something to 2.1.1 a.couple years ago. 2.2.3 is the latest BTW so probably best just to go straight there. Upvote 0 Downvote
Chris D XenForo developer Staff member Licensed customer Feb 3, 2021 #3 You can also one-click upgrade: Install or upgrade? | XenForo If you are not yet running XenForo and want to deploy the self-hosted software to your server, you need to install it. xenforo.com Upvote 0 Downvote
