Awaiting feedback scope problem in xenforo.js Tooltip function
Dan
XenForo.Tooltip = function($element)
     var tipClass = String($element.data('tipclass') || ''),
       isFlipped = /(\s|^)flipped(\s|$)/.test(tipClass),
       offsetY = parseInt($element.data('offsety'), 10) || -6,
       innerWidth = $element.is(':visible') ? $element.innerWidth() : 0,
       dataOffsetX = parseInt($element.data('offsetx'), 10) || 0,
       offsetX = dataOffsetX + innerWidth * (isFlipped ? 1 : -1),
       title = XenForo.htmlspecialchars($element.attr('title'));
     var onBeforeShow = null;
     if (innerWidth <= 0)
       var positionUpdated = false;
       onBeforeShow = function()
         if (positionUpdated)
           return;
         var width = $element.innerWidth();
         if (width <= 0)
           return;
         positionUpdated = true;
         offsetX = dataOffsetX + width * (isFlipped ? 1 : -1);
         $element.data('tooltip').getConf().offset = XenForo.switchOffsetRTL([ offsetY, offsetX ]);
needs to be changed to
Rich (BB code):
           return;
         if (width <= 0)
           return;
         this.getConf().offset = XenForo.switchOffsetRTL([ offsetY, offsetX ]);
$element.data('tooltip') will throw following js error:
TypeError: $element.data(...) is undefined
I'm unclear as to the reason this change is needed. $element is available there and is indeed used immediately before this line. It's not evident why this function would be called without there being a tooltip API already registered and thus fetchable.
Can you include code to reproduce the issue?
