Rebuild position and post counters times out
audiokid
Rebuild Thread Information plus Rebuild position and post counters.
I'm wondering what settings I need to increase on my dedicated server so this doesn't time out?
I've been discovering my server needed increases in the PHP.ini, and a few other area's that have substantially increased the performance after I upped the values.
This especially! http://serverfault.com/questions/355934/500-errors-when-switching-to-fcgi-in-cpanel-whm
What or where do I need to adjust this so it doesn't time out?
Thanks!
You can modify some of php's values directly in xenforo's library/config.php
ini_set('display_errors', true);
ini_set('display_startup_errors', true);
ini_set('max_execution_time', 10000);
ini_set("memory_limit","1024M");
If you rebuild your content in acp>tools>rebuild then you can simply try to set a lower amount of data to be rebuild at each time.
Attached is a CLI rebuild for threads (Note it isn't particularly faster, however it allows you to dump it into a screen and carry on working on other parts of the board as it doesn't used the deferred system)
Upload to your XenForo root directory, edit 'positionRebuild' => false to 'positionRebuild' => true
Then run from CLI.
