XF 2.2 Pub controller class calls init() for some reason when using fastUpdate()
asprin
In my server logs, I'm seeing this message as part of an addon that I'm working on
Error: Call to undefined function Asprin\FB\Pub\Controller\int() src/addons/Asprin/FB/Pub/Controller/Foo.php:293
The stack trace is as follows:
#0 src/addons/Asprin/FB/Pub/Controller/Foo.php(201): Asprin\FB\Pub\Controller\Foo->swapThem(391, 396, 7)
#1 src/XF/Mvc/Dispatcher.php(352): Asprin\FB\Pub\Controller\Foo->actionCheckSwap(Object(XF\Mvc\ParameterBag))
#2 src/XF/Mvc/Dispatcher.php(263): XF\Mvc\Dispatcher->dispatchClass('Asprin\\FB:Foo...', 'CheckSwap', Object(XF\Mvc\RouteMatch), Object(Asprin\FB\Pub\Controller\Foo), NULL)
#3 src/XF/Mvc/Dispatcher.php(115): XF\Mvc\Dispatcher->dispatchFromMatch(Object(XF\Mvc\RouteMatch), Object(Asprin\FB\Pub\Controller\Foo), NULL)
#4 src/XF/Mvc/Dispatcher.php(57): XF\Mvc\Dispatcher->dispatchLoop(Object(XF\Mvc\RouteMatch))
#5 src/XF/App.php(2351): XF\Mvc\Dispatcher->run()
#6 src/XF.php(517): XF\App->run()
#7 index.php(20): XF::runApp('XF\\Pub\\App')
#8 {main}
The class is as follows (the lines specified in stack trace are mentioned below)
<?php
namespace Asprin\FB\Pub\Controller;
use XF\Mvc\ParameterBag;
use XF\Pub\Controller\AbstractController;
use Asprin\FB\Utils as Utils;
class Foo extends AbstractController
    public function actionCheckSwap(ParameterBag $params)
        . some
        . lines
        . of
        . code
        . here
        $this->swapThem($what, $with_what, $pos); // line 201
    public function swapThem($what, $with_what, $pos)
        . some
        . lines
        . of
        . code
        . here
        $foo = $bar->User->Foo; // line 292
        $foo->fastUpdate('counter', ((int)$bar->actioned + 1)); // line 293
Going by the culprit line 293, is this happening because $foo is turning out to null/empty? The problem is that it's not happening always, it's random so I've been having a hard time reproducing the error.
But even if it's a case of null/empty, the error message should say something along the lines of call to undefined function on null or something?
Cannot believe I misread that. It was not init() but int(). So typecasting a value to int is causing the issue.
What I still don't understand though is why it's causing an issue because (int) <value> is pretty standard PHP code, isn't it?
