XF 1.3 Problem With My Test Forum
TheSalt
Hello Gang!
I wanted to do the latest upgrade but in an attempt to be a better admin I decided to tackle making a test forum first. Below are the steps I took.
  1. Backup directory and database
  2. Within the root folder I created a new folder "testforum"
  3. Created a new database "testforum"
  4. Uploaded the backup database to the new database "testforum"
  5. uploaded the back directory files to the root folder "testforum"
  6. updated the .config file to use the "testforum" database
When I loaded www.myforum.com/testforum/ I couldn't sign in. The theme still was rendering but I get a page error "The requested page could not be found." so I tried www.myforum.com/testforum/admin.php and that allowed me to sign into the ACP. I changed the ULR in "Basic Board Information" and saved. It still doesn't allow me to sign in as a member. The theme/skin, members, and content seem to be there but I did notice the xenportal slider images are not rendering. Did I miss a step? Hopefully someone here knows where I went wrong.
Many Thanks:)
Nick
AH! I stand corrected! the threads show up in the forum list but when I click on them I get the same error as when I sign in. "The requested page could not be found."
I noticed I do didnt something. I didnt create a new user and password for the DB so I fixed that, thank you.
It sounds like a Friendly URL issue.
Do the pages work if you disable it in the options?
I unchecked it and everything worked perfectly. It appears that was the problem. Thank you Brogan, again.:D
Something I want to make note of though... I checked the DB sizes against each other and the main forum DB is 73.03 MB and the new one is 62.24 MB. Before seeing your fix I noticed the DB differences and tried to backup and import again. It still showed as 62.24 MB and was doing the same thing. I then turned off the Friendly URL and everything works perfect. Everything seems to be working right on the test forum along with members and content.
I have noticed in the past that is takes some time for the DB size to update on the cpanel. I'm still guilty of using myphpadmin for backups as shell is out of my understanding still. It is on my to learn list. This is also why I worry about the effectiveness of my DB backups.
Thanks again! You all are always so kind and helpful. :love:
Be well,
Nick
Using SSH is fairly straightforward.
I posted some instructions here: http://xenforo.com/community/threads/how-can-i-copy-a-db-dump-to-my-localhost.73038/#post-757333
Essentially the commands are:
Dump:
mysqldump -u<user> -p --single-transaction --skip-lock-tables db_name > /path/to/backup/db_name_$(date +%d.%m.%y).sql
You will be prompted to enter the password.
Zip (optional):
tar -czf db_name_$(date +%d.%m.%y).tar.gz /path/to/backup/db_name_$(date +%d.%m.%y).sql
Restore:
mysql -u<user> -p db_name <db_name.sql
UGH! I'm really trying... I keep getting "mysqldump: Got error: 1045: Access denied for user******* (using password: YES) when trying to connect" after I type in my DB password
Dump:
Zip (optional):
Restore:
Got it worked out! This is awesome! I had to add my IP to the cpanel to allow me to access it via SSH. Thanks so much for the help. I'm working on importing back into the DB using SSH now.
