XF 2.3 Problem with group permissions
Papy___
New member
Hello,
I have XF version 2.3.7 with the Resource Manager module.When I try to modify group permissions to define forum access, I get this message, and the changes don't apply.
I have the same issue with Resource Manager permissions.
when I look at the console I have this
I'm the main admin, so I should have all the rights, so I don't understand where the problem could be coming from.
Thank you for your help....
You don't need to disable it. You need to whitelist the rule that it is triggering. Your host can do this for you. Also @AndyB needs to start replying instead of messaging members.
