Rhody
I converted my last VB4 forum over to Xenforo 2.2 yesterday, and am stumped on an issue.
Everything is otherwise fine, and it was a very smooth transition.
My concern is with redirection of the former VB opening filename, which most users have bookmarked. forum.php This is opening day and our users are getting redirected to a broken page.
When someone goes to ourdomain.com/forum.php or www.ourdomain/forum.php , it is redirecting them to www.www.ourdomain.com/index.php (it is adding an extra "www" to the mix, and failing)
I am using the default .htaccess file that XF installed, with Litespeed server, Litespeed cache add-on installed (does it either way), php 7.4.11, in root folder.
The provider added some code to the default .htaccess file, which I'm including here.
Any help appreciated, to get rid of the extra www.
Mike
Mod_security can interfere with uploading of content such as attachments. If you
# cannot attach files, remove the "#" from the lines below.
#<IfModule mod_security.c>
# SecFilterEngine Off
# SecFilterScanPOST Off
#</IfModule>
ErrorDocument 401 default
ErrorDocument 403 default
ErrorDocument 404 default
ErrorDocument 405 default
ErrorDocument 406 default
ErrorDocument 500 default
ErrorDocument 501 default
ErrorDocument 503 default
<IfModule mod_rewrite.c>
RewriteEngine On
# If you are having problems with the rewrite rules, remove the "#" from the
# line that begins "RewriteBase" below. You will also have to change the path
# of the rewrite to reflect the path to your XenForo installation.
RewriteBase /
# This line may be needed to workaround HTTP Basic auth issues when using PHP as a CGI.
#RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^.*$ - [NC,L]
RewriteRule ^(data/|js/|styles/|install/|favicon\.ico|crossdomain\.xml|robots\.txt) - [NC,L]
</IfModule>
# php -- BEGIN cPanel-generated handler, do not edit
# Set the “alt-php74†package as the default “PHP†programming language.
<IfModule mime_module>
AddHandler application/x-httpd-alt-php74 .php .php7 .phtml
</IfModule>
# php -- END cPanel-generated handler, do not edit
# BEGIN cPanel-generated php ini directives, do not edit
# Manual editing of this file may result in unexpected behavior.
# To make changes to this file, use the cPanel MultiPHP INI Editor (Home >> Software >> MultiPHP INI Editor)
# For more information, read our documentation (https://go.cpanel.net/EA4ModifyINI)
<IfModule php7_module>
php_flag display_errors Off
php_value max_execution_time 90
php_value max_input_time -1
php_value max_input_vars 1000
php_value memory_limit 128M
php_value post_max_size 8M
php_value session.gc_maxlifetime 1440
php_value session.save_path "/opt/alt/php74/var/lib/php/session"
php_value upload_max_filesize 5M
php_flag zlib.output_compression On
</IfModule>
<IfModule lsapi_module>
</IfModule>
# END cPanel-generated php ini directives, do not edit
Mike
