Hi all,
I'm looking to find a way to disable this error message "Oops! We ran into some problems.". I'm aware that instead of disabling it I should resolve the problem but there is no problem actually
The issue / challenge is that we have a DDoS protection (HyperFilter) and currently sometimes some of the JS files are not being loaded due to being blocked by DDoS Filter it's a matter of accessing it first time, after refreshing the page is everything back to normal.
Functionalities are working properly no issues just this popup is quite annoying for the visitors
I hope there is a way to disable this popup.
Thank you,
Thank you,
