Mystrious display problem!
It must be related to a template edit, css change or add-on.
Try checking in a default, unaltered style to see if the problem still exists there.
Check for any outdated templates.
If there are none, disable add-ons one by one to see if the problem disappears.
If it still doesn't resolve it, you will need to revert changes to templates one by one until you identify the cause.
