D
Deleted member 184953
Guest
Hello,
I am having a problem with modifying expressions. When I change the translation of an expression the change is not applied. However if I return to the PCA on the expression my modification is quite persistent.
The only way to apply the change is to export the language and import it again, in which case the changes apply.
I specify that I have just switched xenforo from a local server to a live server. Maybe something happened while importing my database backup.
Thanks for your help.
