Dnyan Well-known member May 11, 2018 #2 I think you need to first upgrade to beta 1 and then to beta 2. Beta 1 adds some columns in db. https://xenforo.com/community/threads/small-error-in-cli-upgrade-2-0-6b2.147166/post-1250180 I am not sure but i saw it on above link Upvote 0 Downvote
mkucuksari Well-known member May 11, 2018 #3 No need to install beta-1. I have made a successful install with using directly beta-2. So the problem must be something different. Upvote 0 Downvote
duderuud Well-known member May 11, 2018 #4 Indeed, I also upgraded from 2.0.5 to 2.0.6b2 without problems. Upvote 0 Downvote
Snog Well-known member May 12, 2018 #7 @Brogan or @Chris D could you try to help the OP? My add-on is being blamed for this because it's throwing a "Unknown column 'protected' in 'field list'.." error when it does an $user->isChanged('xxx') call to XenForo itself and then tries to save the change $user->save(); And I don't think the OP understands it's not my add-on causing the error, it's just revealing it. Which for the most part is the same thing happening here... https://xenforo.com/community/threads/im-having-a-problems-xenforo-2-0-6-beta-2.147203/post-1250569 Last edited: May 12, 2018 Upvote 0 Downvote
shimspedy Well-known member May 12, 2018 #8 please I'm not blaming you addon it just that it also got affected Upvote 0 Downvote
