Baby Community Well-known member Jun 22, 2022 #1 I upgraded to XenForo® v2.2.9. I'm using a theme with minor color change from the default theme. The theme has a minor template issue after this update. I couldn't fix it with Merge, what should I do? Attachments x2.webp 37 KB · Views: 5
P Paul B XenForo moderator Staff member Jun 22, 2022 #3 If you can't merge, revert and re-edit. If it's a third party style, upgrade to a compatible version. Upvote 1 Downvote
Baby Community Well-known member Jun 22, 2022 #4 Brogan said: If you can't merge, revert and re-edit. If it's a third party style, upgrade to a compatible version. Click to expand... I Solved the Problem Upvote 0 Downvote
