Alpha1 Well-known member Feb 18, 2021 #1 I would like to turn all old posts that exclusively contains higher-case text, into sentence case. Is this possible somehow? If so, how? (Query, addon, Kiers post replace addon, or something else)
🔥 🔥Iggy🔥 Well-known member Feb 18, 2021 #2 well with css there is "text-transform"....i know that at least ;P
beerForo Well-known member Feb 18, 2021 #3 CSS sounds like the perfect solution. If you ever have regrets, you can remove it and the db is untouched. Plus, much less work!
