Farques Member Jul 13, 2024 #1 The couple looks like a couple. How can I fix this? Last edited: Jul 13, 2024
Solution ge66 Jul 13, 2024 Farques said: The couple looks like a couple. How can I fix this? View attachment 306010 Click to expand... I think this might help since xf2.3: [cXF] Change default FA node icon Nov 9, 2019 DIY tutorial to change default Font Awesome node icons Especially the "svg {display: none;}" part.
Baby Community Well-known member Jul 13, 2024 #2 I don't understand. Let's see what happens if you give the address of the forum site as a link. Upvote 0 Downvote
Farques Member Jul 13, 2024 #3 Baby Community said: I don't understand. Let's see what happens if you give the address of the forum site as a link. Click to expand... The forum is currently in maintenance mode. I updated the image. Upvote 0 Downvote
Baby Community Well-known member Jul 13, 2024 #4 Farques said: The forum is currently in maintenance mode. I updated the image. Click to expand... Did you upgrade to Xenforo2.3? Upvote 0 Downvote
Baby Community Well-known member Jul 13, 2024 #5 If so, uninstall your theme and any addons that do not support version 2.3. Upvote 0 Downvote
Farques Member Jul 13, 2024 #6 Baby Community said: Did you upgrade to Xenforo2.3? Click to expand... I installed 2.3 directly and installed the webmaster theme shared here. It is shown as 2.3 compatible, but this is the only problem with the theme. Upvote 0 Downvote
Baby Community Well-known member Jul 13, 2024 #7 xenforo2.3 does not support FA and Jquery. Upvote 0 Downvote
Baby Community Well-known member Jul 13, 2024 #8 Farques said: I installed 2.3 directly and installed the webmaster theme shared here. It is shown as 2.3 compatible, but this is the only problem with the theme. Click to expand... There is a problem with the FA of the theme. My advice to you is to buy a theme from licensed xenforo theme developers. For example, I use addon and theme from xentr.net Upvote 0 Downvote
Baby Community Well-known member Jul 13, 2024 #9 Also, baby community is waiting for xenforo2.2.16 patch 2 until my very important addons and theme support xenforo2.3 version. Upvote 0 Downvote
ge66 Well-known member Jul 13, 2024 #10 Farques said: The couple looks like a couple. How can I fix this? View attachment 306010 Click to expand... I think this might help since xf2.3: [cXF] Change default FA node icon Nov 9, 2019 DIY tutorial to change default Font Awesome node icons Especially the "svg {display: none;}" part. Upvote 0 Downvote Solution
Baby Community Well-known member Jul 13, 2024 #11 ge66 said: I think this might help since xf2.3: [cXF] Change default FA node icon Nov 9, 2019 DIY tutorial to change default Font Awesome node icons Especially the "svg {display: none;}" part. Click to expand... What if we don't use FA and try hosting the icons on the server? I said the same thing to the theme author I used. Upvote 0 Downvote
ge66 Well-known member Jul 13, 2024 #12 Baby Community said: What if we don't use FA and try hosting the icons on the server? I said the same thing to the theme author I used. Click to expand... Maybe this? [cXF] Node icons with image Nov 9, 2019 DIY tutorial to change default FA node icons with image Upvote 0 Downvote
