XF 2.1 data and internal_data permission problem
maszd
Hi,
i was moved my forum to new vps with centos 7 running, everything run as expected except there in acp i see this notification:
i was change that two folder to 0777 with this command:
chmod 0777 internal_data
chmod 0777 data
but that notification still appear, is there something missing?
Thanks.
Regards.
If you are still getting permission errors then they haven't been applied correctly - ensure you do it recursively for the whole directory.
Hi ozzy,
thanks for reply, i was run this command:
chown -R nginx:nginx /usr/share/nginx/html
but still that notification appear, before with centos 6 its working fine.
chown changes file/directory ownership
That's not the error. The error is directories/files not writable.
you want
chmod -R -type d 0777 data;
chmod -R  -type d 0777 internal_data;
