Not a bug  Base package problem?
Vincent
Trying to hunt down a problem in addon so did a fresh install using the full package.
In IE clicking the sign up / login buttons throws up an error and the items don't load.
http://xentest.p8ntballer.com/index.php
The fix was posted here by mike: http://xenforo.com/community/threads/fixed-trouble-logging-on-with-ie8.13530/#post-177069
But the error still seems to be included in the main package.
Of course the error occurs in the main package ;)
It will be applied in xF 1.0.1 :D
But you applied the fix and then it still occured? :S
Brogan
#3
That fix was posted after the package was released.
You will need to manually apply the fix until a new release is available.
