$_REQUEST conversion
Mythotical
Ok yes I am working on XFArcade and I can't stand not figuring this out. I thought by changing $_REQUEST to $this->getRequest() that would fix the issue which it did but then the redirect from the game on saving the score stopped working, if I revert then the score part redirects and gives an error. So here is the file using autocom:
class Arcade_Extend_ControllerPublic_Index extends XFCP_Arcade_Extend_ControllerPublic_Index {
    public function actionIndex() {
        if ($this->getRequest('autocom') == 'arcade') {
            // TODO: use filterSingle here?
            switch ($this->getRequest()->getParam('do')) {
                case 'verifyscore':
                    return $this->responseReroute('Arcade_ControllerPublic_Arcade', 'IpbVerifyScore');
                case 'savescore':
                    return $this->responseReroute('Arcade_ControllerPublic_Arcade', 'IpbSaveScore');
                default:
                    return $this->responseNoPermission();
        } else {
            return parent::actionIndex();
    protected function _checkCsrf($action) {
            self::$_executed['csrf'] = true;
            return true;
        } else {
            return parent::_checkCsrf($action);
Just replace $this->getRequest() with $_REQUEST[]
Here is the Session.php line:
        extract($this->_getScoreComparison($reversedScoring));
The error is: Only variables should be passed by reference
Mythotical
Ok ok, I will change it. Right now I have an issue to fix before anything changes. Otherwise it won't matter how I have it, the mod will break.
#6
That function takes a reference parameter:
http://us2.php.net/manual/en/function.extract.php
You need to pass in a variable instead of a value. For example:
$var = $this->_getScoreComparison($reversedScoring);
extract($var);
#8
Thanks much Jake. Any advice on the $_REQUEST issue?
Nothing off hand. I would need to have access to your addon so I can test, debug, and fully explore what is going on. If you are comfortable giving me a copy then I can install it on my forum and have a look.
