XF 2.2 Issue Using FFMpeg library in Addon
XenCircle
By using FFMpeg library i cutt the video of attachment by upload in thread. when i use the FFMpeg library in sandbox its work fine. when i use the library in addon install by composer its create issue.
Any one know about it.
Screenshot attached
Error: Call to undefined method Symfony\Component\Process\Process::setCommandLine() in src/vendor/symfony/process/ProcessBuilder.php at line 269
I think the library is outdated. Symfony Process (which we already include in XF by default) no longer contains a method named setCommandLine.
You would need to change the code of the library or use a newer version, if they have one.
