XF 2.2 Strange problem with permissions
AndrewSimm
I have an addon that for some reason seems to only restrict access to Admins or Moderators despite setting permission for all user groups.
Here is a var_dump from guests that shows permissions to be true.
Here is my class extension
Here is my extended user entity
<?php namespace Andrew\BannedUsersList\XF\Entity; class User extends XFCP_User { public function canViewBannedUsersList(&$error = null) { $visitor = \XF::visitor(); return ($visitor->hasPermission('andrew_banneduserslist', 'canViewBannedUsersList')); } public function canViewBannedBy(&$error = null) { $visitor = \XF::visitor(); return ($visitor->hasPermission('andrew_banneduserslist', 'canViewBannedBy')); } }
Here is the start of my controller
public function actionIndex() { $visitor = \XF::visitor(); if(!$visitor->canViewBannedUsersList()) { return $this->noPermission(); } blah blah blah
I don't see anything wrong with your permission check. Only thing I can think of is it a global permission set? You may just want to try changing this:
to this?
         return $this->hasPermission('andrew_banneduserslist', 'canViewBannedUsersList');
Edit: just thinking that maybe the analyse permission is not as stringent as doing just the check for a visitor, just one thing to eliminate.
to this?
I tried that and still the same thing.
What is odd is that I use the same approach to permissions in all my addons and I only have an issue with this one. I am having the issue on both localhost and my website. No other users of this addon have reported an issue.
Have you tried disabling all other addons to see if it’s a conflict somehow?
Ahh, you got it!
The issue was that I have another addon (Moderator Panel) that also has a banned users list. Both functions in the user entity were called the same thing. I am going to change the name of the one in Moderator Panel since that addon is unreleased.
Thank you sir!
