nocte
I begin with a short summary of the incident:
Recently I activated a route filter for the new “Knowledge Base System” add-on by @Bob. Then I got some user reports, that reactions in DMs don’t work: trying to react gave a 404 error. After I deactivated the route filter, the problem was immediately gone. This is proven by the server logs (we checked the 404 errors).
Now, the interesting part: Re-activating the route filter did not re-trigger any 404 errors. I am simply not able to replicate the issues.
I assume, that some kind of XF-cache was ruined and deactivating the route filter rebuilt/repaired it.
Any ideas what this can be, where to look exactly or how to replicate this?
More details:
My setup has 2 route filters for DMs. Something like
The route filters for Bob’s add-on were something like:
The routes, that caused 404 errors began with a pattern like:
So, this affected direct links to specific DM replies and actions like reacting:
I assumed that something in the
I also looked at the add-on by Bob: It does not contain “replies” a single time.
So, that’s what happened. Has anyone an idea, how this strange behavior may have been triggered?
More details:
conversations/ -> private-messages/direct-messages/ -> private messages/The route filters for Bob’s add-on were something like:
xa-kbs/ -> faq/xa-kbs/categories/ -> faq/areas/The routes, that caused 404 errors began with a pattern like:
private-messages/replies/1234/ (1234 is an example reply ID)So, this affected direct links to specific DM replies and actions like reacting:
private-messages/replies/1234/react?reaction_id=1I assumed that something in the
xf_data_registry table was wrong, but analyzing the binaries showed, that the values were written correctly, both, on enabling and on disabling the route filters.I also looked at the add-on by Bob: It does not contain “replies” a single time.
