I understand that you can change the custom node icons for all forums by changing the image here:
The images changed however they were not centred. Here is what they looked like after changing the default image:
As you can see the icons are not quite right, even though they are 40x40 which is the image size of the default speech bubbles.
I then used this code (below) to correct the background position:
It now looks perfect:
My question is, do I now have to use that code for every single node, or is there just a way of writing one line of code for my EXTRA.css to apply a background position to all forum icons?
Any help would be much appreciated. Thanks.
.node.node_7 .forumNodeInfo .nodeIcon, .node.node_7 .categoryForumNodeInfo .nodeIcon {
background-position: -2px -2px;
.node.node_7 .forumNodeInfo.unread .nodeIcon, .node.node_7 .categoryForumNodeInfo.unread .nodeIcon {
opacity: 0.4;
