ISPr_Winter
Hi All,
I'm new to XenForo and recently purchased and installed the latest v2 release for testing. My first task is to integrate the forum into our existing style, which means I've got a lot of learning to do but currently there is one simple change that I'm trying to figure out.
Essentially I want to ensure that the sidebar is always at the bottom, but still responsive when it's down there like it is now. I never want it to display at the side like it does by default.
At the moment when the window shrinks you see the content scale and the sidebar drop to the bottom, which is fine, but I want it to be at the bottom all the time even in the normal fully expanded view.
I can't see an easy switch to do this so does anybody have any suggestion for a simple code change to make this happen? Thanks.
