Assets are not copied from style archive when using symlinks
Kirby
Affected version
2.2.9
If the path to the temporary directory does contain a symlink somewhere, copying files from a style archive does fail due to
$stdPath = File::stripRootPathPrefix($pathname, $tempDir);
if (!$this->isWithinAssetPath($stdPath, $assetPaths))
    continue;
As $tempDir does not contain the realpath, calling stripRootPathPrefix does nothing and thus isWithinAssetPath returns false which skips the file.
Suggested Solution
Call realpath before returing the path in \XF\Util\File::getTempDir()
Can confirm this is still relevant in 2.3.6.
Modifying /src/XF/Util/File.php and changing the return statement in public static function getTempDir() to
return realpath($path) ?: $path; worked perfect!
Thank you @Kirby!
