Not a bug Route filter does not work for "data/avatars/"
Aivaras
Affected version
2.1.4
Not sure if it is a bug or something else but I cannot replace either data/ or data/avatars/ using route filters in ACP.
One is a file path, the other is a route. One represents a physical path on the file system, the other represents a logical path in the software.
So while you may find an avatar on your file system, e.g. data/avatars/l/38/38615.jpg, you won't find a path such as threads/route-filter-does-not-work-for-data-avatars.170569 or threads/170569 on your file system.
