XF 1.5 Display "Post Number X of Y" top right of each post
ProCom
This is a tricky phrase / item to search for and find. I've done all kinds of iterations and haven't found any hacks or addons. Hopefully someone can help me out?
Basically, at the top-right of every post where the post # is displayed, I'd like to have it show the post number and total number in that thread.
For example:
"3 of 29"
Seems like it would be relatively easy to add, but I have no idea how.
Any suggestions?
Thanks!
There may be a better way... but maybe this will work for you:
Post #{xen:calc '{$post.position} + 1'} of {xen:calc '{$thread.reply_count} + 1'}
Placing that inside the "post" template seems to work.
Thanks @Russ
So, to clarify, I go to the "post" template, and in that, I see multiple tabs. I found "#{xen:calc '{$post.position} + 1'}" in the first "post" tab, and changed it, but it had no effect.
In the "message" tab, I also saw "#{xen:calc '{$post.position} + 1'}", and I replaced that with "Post #{xen:calc '{$post.position} + 1'} of {xen:calc '{$thread.reply_count} + 1'}" and that seems to have done the trick.
Does that sound correct?
(Thanks again for your help)
Update: So, I'm totally novice when it comes to templates, but from what I understand:
The "message" template/ tab is included in the "post" template, and changing the code in the "message" template / tab seems to do the trick on it's own.
If this is incorrect or might cause a problem (or maybe a better way) please let me know :)
