Best way to keep visitors away during installation?
RobParker
I'm planning to move from VB to XF later today and wondered what the best way to keep visitors away during the installation?
Can I just use a .htaccess access file to stop them accessing my site at all?
I'm more worried what will happen as I'm deleting files and uploading the new ones, etc.
If I wanted to send anyone visiting my site to say my twitter page is that possible and how would I exit the .htaccess file to do that?
For example, this htaccess code will redirect everyone to twitter except for your IP address:
<IfModule mod_rewrite.c>
	RewriteEngine On
	RewriteCond %{REMOTE_ADDR} !^12\.34\.56\.78$
	RewriteRule ^.*$ http://www.twitter.com/ [R=302,L]
</IfModule>
Just enter your IP (which will not be redirected) and your twitter URL.
You can use this code replacing 127.0.0.1 with your IP address and example.com with any chosen link to redirect all users there. Just add it to the your index.php
<?php $allow = array("127.0.0.1");
if(!in_array($_SERVER['REMOTE_ADDR'], $allow) && !in_array($_SERVER["HTTP_X_FORWARDED_FOR"], $allow)) {
    header("Location: http://www.example.com/");
    exit();
RewriteEngine On
</IfModule>
How can I add multiple IP addresses?
RewriteEngine On
RewriteCond %{REMOTE_ADDR} !^11\.22\.33\.44$
RewriteCond %{REMOTE_ADDR} !^44\.33\.22\.11$
</IfModule>
I used this but it is not redirecting to it.
