Fixed  Strange Problem: phrase map rebuild timeout
LokizeGames
New member
Hi guys I'm having some strange problems among them below, to access the language the phrases do not appear, and sometimes mysteriously appear, do not know how to solve this problem!?
Below I'll post another unsolved problem also when trying to install the forum several times getting this error, and every time I try to install any application error occurs again, I'm going crazy!
Mike
Can I just say that LMGTFY links really aren't appreciated? Yes I understand the point, but they're not helpful. Ideally, this should help: http://forums.iis.net/t/1076662.aspx
Though that said, this seems to be a common problem and I can all but guarantee that it's the phrase map rebuild part of the process, so I guess I need to put together the fix for 1.0.3 and post it here. Will do that shortly.
Mike
In library/XenForo/Model/Phrase.php, replace the whole insertPhraseMapForLanguages function:
    public function insertPhraseMapForLanguages(array $languageMapList, $truncate = false)
        $db = $this->_getDb();
        XenForo_Db::beginTransaction($db);
        if ($truncate)
            $db->query('TRUNCATE TABLE xf_phrase_map');
        foreach ($languageMapList AS $builtLanguageId => $map)
            if (!$truncate)
                $db->delete('xf_phrase_map', 'language_id = ' . $db->quote($builtLanguageId));
            foreach ($map AS $title => $phraseId)
                $db->insert('xf_phrase_map', array(
                    'language_id' => $builtLanguageId,
                    'title' => $title,
                    'phrase_id' => $phraseId
        XenForo_Db::commit($db);
with this version:
        if ($truncate)
        $rows = array();
        $rowLength = 0;
            if (!$truncate)
            $builtLanguageIdQuoted = $db->quote($builtLanguageId);
                $row = '(' . $builtLanguageIdQuoted . ', ' . $db->quote($title) . ',' . $db->quote($phraseId) . ')';
                $rows[] = $row;
                $rowLength += strlen($row);
                if ($rowLength > 500000)
                    $db->query('
                        INSERT INTO xf_phrase_map
                            (language_id, title, phrase_id)
                        VALUES
                            ' . implode(',', $rows)
                    $rows = array();
                    $rowLength = 0;
        if ($rows)
            $db->query('
                VALUES
                    ' . implode(', ', $rows)
        if ($truncate)
            if (!$truncate)
                    'title' => $title,
with this version:
        if ($truncate)
        $rows = array();
        $rowLength = 0;
            if (!$truncate)
                $rows[] = $row;
                    $db->query('
                        VALUES
                    $rows = array();
                    $rowLength = 0;
        if ($rows)
            $db->query('
                VALUES
Thanks, but this problem continues
Look I'm sorry to say this, but the second problem, never happened to me using the platform vbulletin or IPB, I think it's a problem xenforo, because it takes longer than 60 seconds to install the forum, and of course the addons, and the fact that it takes more than 60 seconds is generating this problem!
And, sorry but the error not [Fixed]...(n)
