Removing "index.php" from my web url - htacess help
Ranger375
How would I edit this htaccess file to remove the "index.php" from my forum address. My current address looks like this http://mysite.com/vb/index.php. Using mysite.com/vb works, but the index.php is still displayed.
<IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteRule ^.*$ - [NC,L]
    RewriteRule ^(data|js|styles|install) - [NC,L]
</IfModule>
F
Floris
Guest
#2
Your directory is /vb/ but I assume you are running XenForo inside /vb/ ?
Leave the .htaccess in the dir you run xenforo from, and from the options > seo > use smexy urls : yes.
And you're done.
Ranger375
Thanks, worked perfectly.
Yeah, replacing my vb with my xf, but don't want to change the directory name to avoid all the confusion that goes with it :\
