Problems with spacing on embedded code
Lone Wolf
I run a sports website and on vbulletin we used to use the code function to create game scorecards. We could use tabs in notepad to create a properly spaced scorecard as in the example below...
Purple vs. Green
Green Innings
Player                Status                        R    B    4s    6s    S/R
Umar Akmal            lbw Abdul Razzaq              0    1     0    0    0
Misbah ul Haq         c Abdul Razzaq b Omar        51    36    6    0    141.7
Shan Masood            lbw Omar                    59    43    8    0    137.2
Shakeel Ansar         c Omar b Abdul Razzaq        26    16    4    0    162.5
Total: 175                    Overs: 20.0                Run Rate: 8.75
Extras : 9    No Balls : 2      Wides : 4    Leg Byes : 3        Byes : 0
However when I do the same thing on XenForo the spacing is all wrong as in the example below...
Purple vs. Green
Green Innings
In order to correctly space the second scorecard to resemble the first scorecard I have to individually edit the spaces on each line to make it match up correctly. This is really time consuming and I cant understand why it doesnt 'just work' like it used to on vbulletin.
Does anyone know how to create correctly spaced (via tabs) scorecards with XenForo code the way I can with vbulletin.
Chris D
What if you change the font in the editor to Courier New? Does it give you the desired effect more than if you used the [code] function?
The code block works the same in XF. I suspect this is a problem with the rich editor which is known to hijack formatting. Try using the plain text editor.
