Not a bug  Problem with special charakters and umlauts in url
twollert
With Beta 2:
My thread "Test äöüß 1234" converts to http://www.xyz.com/index.php?threads/test-äöüß-1234.31694 in the url.
(Should be http://www.xyz.com/index.php?threads/[URL='http://www.radioforen.de/showthread.php?47365-Test-äöüß-1234&p=537795#post537795']Test-äöüß-1234.31694[/URL])
This behavior depends on the browser. IE will display the urlencoded string; basically everything else displays the characters properly. If accented characters are going to remain in the URL, there's no other option. (Not encoding it is a violation of specs and causes problems in some instances.) Stripping/transliterating characters would be a suggestion (that I think has been posted).
Thanks for your answer, Mike!
Right, the problem seems to appear only in IE (checked with Internet Explorer, Firefox and Chrome).
But: I'm currently using vBulletin and with that IE displays all properly. What's the reason it didn't work with XenForo?
