Problem with posts.
Digital Doctor
You've tried more than one computer ? more than 1 browser ?
What addons have you changed ? added ?
You've given so little information, it doesn't seem like you want to fix your issue.
Digital Doctor
When you press enter on a post, it doesn't appear in the actual post once submitting it. I'm wondering what the problem is! The posts also appear in HTML when you go to edit them too, which is the cause I guess :)
It was the visual text editor ;)
Hmmm.
Xenforo's editor (TinyMCE) seems to strip out line breaks (or enters as you called them), especially if you put alot in a row ... or some at the end of a post.
Do you know about the plain text bbcode editor ... ?
or minorin ?
ZINC
New member
#10
Hmmm.
or minorin ?
I haven't heard of those? It that a XF term? I haven't realy played around with settings :p
ZINC
New member
#12
I enabled some light box thing and stopped it auto-embedding links and I think it works correctly now! :)
Edit: ahhh ok, I'll do that! Thanks!
ZINC
New member
#18
Guys, it's broken again :(
This is what posts apear as when quoting them:
<p>[quote=&quot;ZINC, post: 959, member: 1&quot;]TEST[/quote]</p>
<p><br /></p>
