XF 1.1 Mark as read problem
Onimua
Not the language, the templates–the HTML of that dialog. Can you post the contents of your forum_mark_read template?
#5
Here:
<xen:title>{xen:phrase mark_forums_read}</xen:title>
<form action="{xen:link forums/-/mark-read}" method="post" class="xenForm formOverlay AutoValidator" data-redirect="on">
    <xen:if is="{$forum}">
        <p>{xen:phrase which_forums_do_you_want_to_mark_as_read}</p>
        <dl class="ctrlUnit">
            <dt></dt>
            <dd>
                <ul>
                    <li><label><input type="radio" name="node_id" value="{$forum.node_id}" checked="checked" /> {$forum.title}</label></li>
                    <li><label><input type="radio" name="node_id" value="0" /> {xen:phrase mark_all_forums_read}</label></li>
                </ul>
            </dd>
        </dl>
        <dl class="ctrlUnit submitUnit">
            <dt></dt>
            <dd>
                <input type="submit" value="{xen:phrase mark_forums_read}" class="button primary" />
            </dd>
        </dl>
    <xen:else />
        <p>{xen:phrase you_sure_you_want_to_mark_all_forums_read}</p>
            <dt></dt>
            <dd>
                <input type="submit" value="{xen:phrase mark_all_forums_read_button}" class="button primary" />
            </dd>
        </dl>
    </xen:if>
    <input type="hidden" name="date" value="{$markDate}" />
    <input type="hidden" name="_xfToken" value="{$visitor.csrf_token_page}" />
    <input type="hidden" name="_xfConfirm" value="1" />
</form>
#7
Yes, is the default, we have 2 styles hardware and games. This is games:
            <dt></dt>
            <dd>
                <ul>
                </ul>
            </dd>
        </dl>
            <dt></dt>
            <dd>
            </dd>
        </dl>
    <xen:else />
            <dt></dt>
            <dd>
            </dd>
        </dl>
    </xen:if>
</form>
The Style is defined in the extra.css
#8
Also try reverting this template:
Admin CP -> Appearance -> Templates -> navigation
In particular, the code for the Forums tab:
Rich (BB code):
		<!-- forums -->
		<xen:if is="{$tabs.forums}">
			<li class="navTab forums {xen:if $tabs.forums.selected, 'selected', 'Popup PopupControl PopupClosed'}">
				<a href="{$tabs.forums.href}" class="navLink">{$tabs.forums.title}</a>
				<a href="{$tabs.forums.href}" class="SplitCtrl" rel="Menu"></a>
				<div class="{xen:if {$tabs.forums.selected}, 'tabLinks', 'Menu JsOnly tabMenu'}">
					<div class="primaryContent menuHeader">
						<h3>{$tabs.forums.title}</h3>
						<div class="muted">{xen:phrase quick_links}</div>
					</div>
					<ul class="secondaryContent blockLinksList">
					<xen:hook name="navigation_tabs_forums">
						<xen:if is="{$visitor.user_id}"><li><a href="{xen:link 'forums/-/mark-read', $forum, 'date={$serverTime}'}" class="OverlayTrigger">{xen:phrase mark_forums_read}</a></li></xen:if>
						<xen:if is="{$canSearch}"><li><a href="{xen:link search, '', 'type=post'}">{xen:phrase search_forums}</a></li></xen:if>
						<xen:if is="{$visitor.user_id}"><li><a href="{xen:link 'watched/threads'}">{xen:phrase watched_threads}</a></li></xen:if>
						<li><a href="{xen:link 'find-new/threads'}">{xen:phrase whats_new}</a></li>
					</xen:hook>
					</ul>
				</div>
			</li>
		</xen:if>
#9
Rich (BB code):
<!-- forums -->
</div>
</xen:hook>
</ul>
</div>
</li>
</xen:if>
Thank! This worsk! In m forum tabs had this:
<!-- forums -->
                    </div>
                        <xen:if is="{$visitor.user_id}"><li><a href="{xen:link 'forums/-/mark-read', '', 'date={$serverTime}'}" class="OverlayTrigger">{xen:phrase mark_all_forums_read}</a></li></xen:if>
                    </xen:hook>
                    </ul>
                </div>
            </li>
        </xen:if>
