XF 1.2 i have an problem with defaults usergroups
Liam W
I suggest you rebuild master data, /install and click the button.
It looks like something went wrong when reparsing the permissions.
Liam
Liam W
Like I said, go to /install and click the button to rebuild master data.
There will be no data loss.
Liam
Liam W
Did you let it run through completely?
Have you tried disabling all addons? If so, and it still happens when you've rebuilt the data after disabling addons, then submit a ticket.
Liam
Liam W
You are already running the current version (1.2.4). To do a fresh install, click here. what dose it mean do an fresh install will i lose all members
There should be a link to rebuild master data.
It's a button. The link will destroy data, the button won't and should fix the issue once addobs are disabled.
