Hotlink protection help (not xenforo related)
Kaiser
Is it better to have it on or off? Or it really dosent matter? Currently I have it turned on. I have a question, like say my avatar I have it uploaded on my forum, I link to it and put it on my avatar on other forums (http://adminbb.org/data/avatars/l/0/1.jpg) Shouldnt hotlinking disable this so I cant use use it on other forums?
Thanks in advance.
Brogan
If you enable hotlink protection, then any files with the extensions you specify, won't be able to be embedded on other sites/domains.
You can optionally specify an image to replace any embedded images.
As to whether it's better on or off, that's a personal preference and largely depends on your content and how much bandwidth is utilised by other sites embedding images.
Kaiser
Im still c0nfused, im embedding the pic above from my site into the post. Isnt that hotlinking though?
Brogan
It is.
Check the .htaccess file in your domain root.
It should contain something like this:
RewriteEngine on
RewriteCond %{HTTP_REFERER} !^$
RewriteCond %{HTTP_REFERER} !^http://adminbb.org/.*$ [NC]
RewriteCond %{HTTP_REFERER} !^http://adminbb.org$ [NC]
RewriteCond %{HTTP_REFERER} !^http://www.adminbb.org/.*$ [NC]
RewriteCond %{HTTP_REFERER} !^http://www.adminbb.org$ [NC]
RewriteRule .*\.(jpeg|gif|bmp|png|jpg)$ hotlinking.jpg [L]
The last line is where you specify the file extensions and an image to display in place of any embedded files.
Kaiser
It is.
RewriteEngine on
I have it but still not working?
What my .htacess has
<IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteRule ^.*$ - [NC,L]
    RewriteRule ^(data|js|styles|install) - [NC,L]
</IfModule>
RewriteRule .*\.(jpg|jpeg|gif|png|bmp)$ - [F,NC]
RewriteRule .*\.(zip|txt|pdf|png|jpg|jpeg|jpe|gif|rar)$ - [F,NC]
OperaManiac
sort of off-topic but i have been using the hotlink feature provided by cloudflare on my own site. works great. :p
