daviden
Started getting my server error log filled with errors yesterday.
Problem is connecting to the email server. This makes the forum and conversation posting very very slow (timeouting). Of course only for the threads that's being subscribed to and conversations that users choose to be alerted on via email.
One of the error messages:
Running on VPS, email through same provider (via SMTP, not locally on the VPS). Called my provider and asked if I've been blacklisted, but nope - all green.
Also tried the exact same settings through other email clients and I'm sure that the SMTP server works.
...help?
Server Error Log
Error Info
Zend_Mail_Protocol_Exception: Connection timed out - library/Zend/Mail/Protocol/Abstract.php:277
Generated By: Micke Ni, 2 minuter sedan
Stack Trace
#0 /var/www/library/Zend/Mail/Protocol/Smtp.php(167): Zend_Mail_Protocol_Abstract->_connect('ssl://mail.kloc...')
#1 /var/www/library/Zend/Mail/Transport/Smtp.php(199): Zend_Mail_Protocol_Smtp->connect()
#2 /var/www/library/Zend/Mail/Transport/Abstract.php(348): Zend_Mail_Transport_Smtp->_sendMail()
#3 /var/www/library/Zend/Mail.php(1194): Zend_Mail_Transport_Abstract->send(Object(Zend_Mail))
#4 /var/www/library/XenForo/Mail.php(177): Zend_Mail->send()
#5 /var/www/library/XenForo/Mail.php(152): XenForo_Mail->sendMail(Object(Zend_Mail))
#6 /var/www/library/XenForo/Mail.php(204): XenForo_Mail->send('patrik.ekestubb...', 'Patrike', Array, '', '', '')
#7 /var/www/library/XenForo/Model/ThreadWatch.php(242): XenForo_Mail->queue('patrik.ekestubb...', 'Patrike')
#8 /var/www/library/XenForo/DataWriter/DiscussionMessage/Post.php(108): XenForo_Model_ThreadWatch->sendNotificationToWatchUsersOnReply(Array, NULL, Array)
#9 /var/www/library/bdTagMe/XenForo/DataWriter/DiscussionMessage/Post.php(29): XenForo_DataWriter_DiscussionMessage_Post->_postSaveAfterTransaction()
#10 /var/www/library/XenForo/DataWriter.php(1399): bdTagMe_XenForo_DataWriter_DiscussionMessage_Post->_postSaveAfterTransaction()
#11 /var/www/library/XenForo/ControllerPublic/Thread.php(504): XenForo_DataWriter->save()
#12 /var/www/library/sonnb/LiveThread/ControllerPublic/Thread.php(324): XenForo_ControllerPublic_Thread->actionAddReply()
#13 /var/www/library/XenForo/FrontController.php(310): sonnb_LiveThread_ControllerPublic_Thread->actionAddReply()
#14 /var/www/library/XenForo/FrontController.php(132): XenForo_FrontController->dispatch(Object(XenForo_RouteMatch))
#15 /var/www/index.php(13): XenForo_FrontController->run()
#16 {main}
Request State
array(3) {
["url"] => string(70) "http://klocksnack.se/threads/fin-klocka-p%C3%A5-jobbet.16125/add-reply"
["_GET"] => array(0) {
["_POST"] => array(7) {
["message"] => string(483) "[quote="Frosse, post: 296663, member: 1721"]Det sägs väl att man ska anpassa sin klocka till sin motpart, det vill säga sitter du i förhandlingar om en stor order, uppköp etc. så ska du alltid lägga dig en nivå lägre än din motpart så att denne känner sig i överläge. Rent psykologiskt ger det dig tydligen ett överläge.[/quote]
Intressant, det ger i så fall båda parter ett överläge då man gör klokast i att utgå från att motparten har samma info...
["_xfRelativeResolver"] => string(61) "http://klocksnack.se/threads/fin-klocka-p%C3%A5-jobbet.16125/"
["last_date"] => string(10) "1387108053"
["_xfRequestUri"] => string(41) "/threads/fin-klocka-p%C3%A5-jobbet.16125/"
...help?
