Reset signatures with help of SQL query?
fredrikse
Hi,
I would like to reset the signature field in xenForo after migration from vB is completed. What would the SQL query for that be?
Hi,
By resetting you mean to truncate/delete all signatures for everyone? If so run this query at the SQL box in phpmyadmin
UPDATE xf_user_profile
SET signature = '';
If you are using another prefix for your tables, replace xf_ with your custom prefix at the queries above. Hope it helps.
